Mon HTACCESS a-t-il un problème ??
27 Avr 2010 17:38 #1 par jeanmi31
Mon HTACCESS a-t-il un problème ?? a été créé par jeanmi31
Vous trouverez ci-dessous mon HTACCESS et pouvez-vous me dire si vous voyez une erreur car j'ai une erreur 500 :
# @version $Id: htaccess.txt 10492 2008-07-02 06:38:28Z ircmaxell $
# @package Joomla
# @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
# @license www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
#Options +FollowSymLinks
# mod_rewrite in use
RewriteEngine On
############# Use this section if using ONLY Joomla! core SEF
## ALL (RewriteCond) lines in this section are only required if you actually
## have directories named 'content' or 'component' on your server
## If you do not have directories with these names, comment them out.
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteCond %{REQUEST_URI} ^(/component/option,com) [NC,OR] ##optional - see notes##
#RewriteCond %{REQUEST_URI} (/|\.htm|\.php|\.html|/[^.]*)$ [NC]
#RewriteRule ^(content/|component/) index.php
########## Begin - 3rd Party SEF Section
############# Use this section if you are using a 3rd party (Non Joomla! core) SEF extension - e.g. OpenSEF, 404_SEF, 404SEFx, SEF Advance, etc
RewriteRule (.*) index.php
########## End - 3rd Party SEF Section
#RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR]
#RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR]
#RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR]
#RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR]
#RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2})
#RewriteRule ^(.*)$ index.php [F,L]
RewriteBase /
#RewriteCond %{REQUEST_URI} !^/index.php
#RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC]
#RewriteRule (.*) index.php
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# Pour faire parser les fichiers ".php" par PHP5
AddType application/x-httpd-php5 .php
#ErrorDocument 500 http://www.votre_domaine.com/500.html
27 Avr 2010 21:59 #2 par lavsteph
Réponse de lavsteph sur le sujet Re:Mon HTACCESS a-t-il un problème ??
je ne connais pas spécialement ton hébergeur, à première vue cela me semble pas trop mal.
Reste qu'il nous faudrait plus d'informations pour t'aider, dont les paramètres de configuration SEF de joomla.
27 Avr 2010 22:22 #3 par jeanmi31
Réponse de jeanmi31 sur le sujet Re:Mon HTACCESS a-t-il un problème ??
lavsteph écrit:
Je suis débutant qu'appelez vous les paramères du sef ?? Merci...
27 Avr 2010 22:56 #4 par lavsteph
Ce sont les paramètres de l'onglet Site de la configuration générale de Joomla.
  • toutbaigne
  • Hors Ligne
  • Membre premium
  • Membre premium
  • Aimer c'est agir !
05 Mai 2010 17:45 - 05 Mai 2010 18:38 #5 par toutbaigne
Réponse de toutbaigne sur le sujet Re:Mon HTACCESS a-t-il un problème ??
Le mien aussi me pose des problèmes...
Il n'accepte pas les accents, dés que je met un accent dans le module de recherche, il m'affiche une erreure 404.
D'ou peu venir le problème?
SetEnv REGISTER_GLOBALS 0 SetEnv ZEND_OPTIMIZER 1 SetEnv MAGIC_QUOTES 1 SetEnv PHP_VER 5 ## # @version $Id: htaccess.txt 10492 2008-07-02 06:38:28Z ircmaxell $ # @package Joomla # @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved. # @license http://www.gnu.org/copyleft/gpl.html GNU/GPL # Joomla! 1.5 is Free Software # Ehanced protected filters by Sirius http://www.octeam.fr VERSION DU 2009-05-28 # Support at Joomla Forum http://forum.joomla.fr/showthread.php?t=89166 # Modifications in this file are not part of the original Joomla package ! # PROTECTION FORTE HTACCESS <Files ~ "^.*\.([Hh][Tt][Aa])"> order allow,deny deny from all </Files> # PROTECTION FICHIERS PAR EXTENSIONS # AJOUTEZ CELLES QUE VOUS SOUHAITEZ SI BESOIN <FilesMatch "\.(htaccess|htpasswd|ini|phps|log|sh|.*sql)$"> Order Allow,Deny Deny from all </FilesMatch> # PROTECTION FICHIERS UNIQUE <Files configuration.php> deny from all </Files> ## LIMITE TAILLE UPLOAD POST CONTRE LES ATTAQUES DOS # PAR DEFAUT A 1MO (1024000 = 1Mo) # ATTENTION SI ACTIF, PEU GENERER UNE ERREUR 500 SELON VOTRE HEBERGEMENT #bytes, 0-2147483647(2GB) #LimitRequestBody 1024000 # 1Mo # ESSENTIELS RewriteEngine on ServerSignature Off Options All -Indexes Options +FollowSymLinks # FILTER REQUEST METHODS <IfModule mod_rewrite.c> RewriteCond %{REQUEST_METHOD} ^(HEAD|TRACE|DELETE|TRACK) [NC] RewriteRule ^(.*)$ - [F,L] RewriteCond %{QUERY_STRING} ^(.*&)?full_path_to_public_program=http:// RewriteRule ^(.*/)?includes/smarty\.php$ - [F,L] </IfModule> # QUERY STRING EXPLOITS <IfModule mod_rewrite.c> RewriteCond %{QUERY_STRING} \.\.\/ [NC,OR] RewriteCond %{QUERY_STRING} boot\.ini [NC,OR] RewriteCond %{QUERY_STRING} tag\= [NC,OR] RewriteCond %{QUERY_STRING} ftp\: [NC,OR] RewriteCond %{QUERY_STRING} http\: [NC,OR] RewriteCond %{QUERY_STRING} https\: [NC,OR] RewriteCond %{QUERY_STRING} mosConfig [NC,OR] RewriteCond %{QUERY_STRING} ^.*(\(|\)|<|>|'|"|\?|\*).* [NC,OR] RewriteCond %{QUERY_STRING} ^.*(%22|%27|%3C|%3D|%3E|%7B|%7C).* [NC,OR] RewriteCond %{QUERY_STRING} ^.*(%0|%A|%B|%C|%D|%F|127\.0).* [NC,OR] RewriteCond %{QUERY_STRING} ^.*(globals|encode|localhost|loopback).* [NC,OR] RewriteCond %{QUERY_STRING} ^.*(select|union|declare|drop).* [NC] RewriteRule ^(.*)$ - [F,L] </IfModule> # CHARACTER STRINGS <IfModule mod_alias.c> # BASIC CHARACTERS #RedirectMatch 403 \, RedirectMatch 403 \: RedirectMatch 403 \; RedirectMatch 403 \= RedirectMatch 403 \@ RedirectMatch 403 \[ RedirectMatch 403 \] RedirectMatch 403 \^ RedirectMatch 403 \` RedirectMatch 403 \{ RedirectMatch 403 \} RedirectMatch 403 \~ RedirectMatch 403 \" RedirectMatch 403 \$ RedirectMatch 403 \< RedirectMatch 403 \> RedirectMatch 403 \| RedirectMatch 403 \.\. RedirectMatch 403 \/\/ RedirectMatch 403 \%0 RedirectMatch 403 \%A RedirectMatch 403 \%B RedirectMatch 403 \%C RedirectMatch 403 \%D RedirectMatch 403 \%E RedirectMatch 403 \%F RedirectMatch 403 \%22 RedirectMatch 403 \%27 RedirectMatch 403 \%28 RedirectMatch 403 \%29 RedirectMatch 403 \%3C RedirectMatch 403 \%3E RedirectMatch 403 \%3F RedirectMatch 403 \%5B RedirectMatch 403 \%5C RedirectMatch 403 \%5D RedirectMatch 403 \%7B RedirectMatch 403 \%7C RedirectMatch 403 \%7D # COMMON PATTERNS RedirectMatch 404 wp\_ Redirectmatch 403 \_vpi RedirectMatch 403 \.inc Redirectmatch 403 xAou6 Redirectmatch 403 db\_name Redirectmatch 403 select\( Redirectmatch 403 convert\( Redirectmatch 403 \/query\/ RedirectMatch 403 ImpEvData Redirectmatch 403 \.XMLHTTP Redirectmatch 403 proxydeny RedirectMatch 403 function\. Redirectmatch 403 remoteFile Redirectmatch 403 servername Redirectmatch 403 \&rptmode\= Redirectmatch 403 sys\_cpanel RedirectMatch 403 db\_connect RedirectMatch 403 doeditconfig RedirectMatch 403 check\_proxy Redirectmatch 403 system\_user Redirectmatch 403 \/\(null\)\/ Redirectmatch 403 clientrequest Redirectmatch 403 option\_value RedirectMatch 403 ref\.outcontrol # SPECIFIC EXPLOITS RedirectMatch 403 errors\. #RedirectMatch 403 config\. RedirectMatch 403 include\. RedirectMatch 403 display\. RedirectMatch 403 register\. Redirectmatch 403 password\. RedirectMatch 403 maincore\. RedirectMatch 403 authorize\. Redirectmatch 403 macromates\. RedirectMatch 403 head\_auth\. RedirectMatch 403 submit\_links\. RedirectMatch 403 change\_action\. Redirectmatch 403 com\_facileforms\/ RedirectMatch 403 admin\_db\_utilities\. RedirectMatch 403 admin\.webring\.docs\. Redirectmatch 403 Table\/Latest\/index\. </IfModule> # PROTECTION FICHIERS UNIQUE <Files config.php> deny from all </Files> ##################################################### # USER AGENTS SetEnvIfNoCase User-Agent "libwww" keep_out SetEnvIfNoCase User-Agent "libwww-perl" keep_out SetEnvIfNoCase User-Agent "DotBot" keep_out SetEnvIfNoCase User-Agent "Jakarta Commons" keep_out SetEnvIfNoCase User-Agent "Y!OASIS/TEST" keep_out SetEnvIfNoCase User-Agent "MOT-MPx220" keep_out SetEnvIfNoCase User-Agent "MJ12bot" keep_out SetEnvIfNoCase User-Agent "Nutch" keep_out SetEnvIfNoCase User-Agent "cr4nk" keep_out <Limit GET POST PUT> Order Allow,Deny Allow from all Deny from env=keep_out </Limit> ################### Ban ################## ############### PAGE INTERDICTION PERSO ################### ErrorDocument 403 http://www.XXXXX.com/erreures.html ############################################ # READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE # # The line just below this section: 'Options +FollowSymLinks' may cause problems # with some server configurations. It is required for use of mod_rewrite, but may already # be set by your server administrator in a way that dissallows changing it in # your .htaccess file. If using it causes your server to error out, comment it out (add # to # beginning of line), reload your site in your browser and test your sef url's. If they work, # it has been set by your server administrator and you do not need it set here. # # Only use one of the two SEF sections that follow. Lines that can be uncommented # (and thus used) have only one #. Lines with two #'s should not be uncommented # In the section that you don't use, all lines should start with # # ##################################################### ## Can be commented out if causes errors, see notes above. # mod_rewrite in use # ESSENTIELS RewriteEngine on ServerSignature Off Options All -Indexes Options +FollowSymLinks ########## Begin - Rewrite rules to block out some common exploits ## If you experience problems on your site block out the operations listed below ## This attempts to block the most common type of exploit `attempts` to Joomla! ########## Begin - Rewrite rules to block out some common exploits ## If you experience problems on your site block out the operations listed below ## This attempts to block the most common type of exploit `attempts` to Joomla! # Block out any script trying to set a mosConfig value through the URL RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR] # Block out any script trying to base64_encode crap to send via URL RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR] # Block out any script that includes a <script> tag in URL #RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR] # Block out any script trying to set a PHP GLOBALS variable via URL RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR] # Block out any script trying to modify a _REQUEST variable via URL RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2}) [OR] # securite en plus RewriteCond %{QUERY_STRING} ^.*(;|<|>|'|"|\)|%0A|%0D|%22|%27|%3C|%3E|%00).*(/\*|union|select|insert|cast|set|declare|drop|update|md5|benchmark).* [NC,OR] RewriteCond %{QUERY_STRING} ^.*(localhost|loopback|127\.0\.0\.1).* [NC,OR] #RewriteCond %{QUERY_STRING} ^.*\.[A-Za-z0-9].* [NC,OR] RewriteCond %{QUERY_STRING} ^.*(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC,OR] # Disable TRACE & TRACK methods RewriteCond %{REQUEST_METHOD} ^(HEAD|TRACE|DELETE|TRACK) [NC,OR] RewriteCond %{THE_REQUEST} ^.*(\\r|\\n|%0A|%0D).* [NC,OR] RewriteCond %{HTTP_REFERER} ^(.*)(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC,OR] #RewriteCond %{HTTP_COOKIE} ^.*(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC,OR] # RewriteCond %{REQUEST_URI} ^/(,|;|:|<|>|">|"<|/|\\\.\.\\).{0,9999}.* [NC,OR] RewriteCond %{HTTP_USER_AGENT} ^$ [OR] #RewriteCond %{HTTP_USER_AGENT} ^(java|curl|wget).* [NC,OR] RewriteCond %{HTTP_USER_AGENT} ADSARobot|ah-ha|almaden|aktuelles|Anarchie|amzn_assoc|ASPSeek|ASSORT|ATHENS|Atomz|attach|attache|autoemailspider|BackWeb|Bandit|BatchFTP|bdfetch|big.brother|BlackWidow|bmclient|Boston\ Project|BravoBrian\ SpiderEngine\ MarcoPolo|Bot\ mailto:|Buddy|Bullseye|bumblebee|capture|CherryPicker|ChinaClaw|CICC|clipping|Collector|Copier|Crescent|Crescent\ Internet\ ToolPak|Custo|cyberalert|DA$|Deweb|diagem|Digger|Digimarc|DIIbot|DISCo|DISCo\ Pump|DISCoFinder|Download\ Demon|Download\ Wonder|Downloader|Drip|DSurf15a|DTS.Agent|EasyDL|eCatch|ecollector|efp@gmx\.net|Email\ Extractor|EirGrabber|email|EmailCollector|EmailSiphon|EmailWolf|Express\ WebPictures|ExtractorPro|EyeNetIE|FavOrg|fastlwspider|Favorites\ Sweeper|Fetch|FEZhead|FileHound|FlashGet\ WebWasher|FlickBot|fluffy|FrontPage|GalaxyBot|Generic|Getleft|GetRight|GetSmart|GetWeb!|GetWebPage|gigabaz|Girafabot|Go\!Zilla|Go!Zilla|Go-Ahead-Got-It|GornKer|gotit|Grabber|GrabNet|Grafula|Green\ Research|grub-client|Harvest|hhjhj@yahoo|hloader|HMView|HomePageSearch|http\ generic|HTTrack|httpdown|httrack|ia_archiver|IBM_Planetwide|Image\ Stripper|Image\ Sucker|imagefetch|IncyWincy|Indy*Library|Indy\ Library|informant|Ingelin|InterGET|Internet\ Ninja|InternetLinkagent|Internet\ Ninja|InternetSeer\.com|Iria|Irvine|JBH*agent|JetCar|JOC|JOC\ Web\ Spider|JustView|KWebGet|Lachesis|larbin|LeechFTP|LexiBot|lftp|libwww|likse|Link|Link*Sleuth|LINKS\ ARoMATIZED|LinkWalker|LWP|lwp-trivial|Mag-Net|Magnet|Mac\ Finder|Mag-Net|Mass\ Downloader|MCspider|Memo|Microsoft.URL|MIDown\ tool|Mirror|Missigua\ Locator|Mister\ PiX|MMMtoCrawl\/UrlDispatcherLLL|^Mozilla$|Mozilla.*Indy|Mozilla.*NEWT|Mozilla*MSIECrawler|MS\ FrontPage*|MSFrontPage|MSIECrawler|MSProxy|multithreaddb|nationaldirectory|Navroad|NearSite|NetAnts|NetCarta|NetMechanic|netprospector|NetResearchServer|NetSpider|Net\ Vampire|NetZIP|NetZip\ Downloader|NetZippy|NEWT|NICErsPRO|Ninja|NPBot|Octopus|Offline\ Explorer|Offline\ Navigator|OpaL|Openfind|OpenTextSiteCrawler|OrangeBot|PageGrabber|Papa\ Foto|PackRat|pavuk|pcBrowser|PersonaPilot|Ping|PingALink|Pockey|Proxy|psbot|PSurf|puf|Pump|PushSite|QRVA|RealDownload|Reaper|Recorder|ReGet|replacer|RepoMonkey|Robozilla|Rover|RPT-HTTPClient|Rsync|Scooter|SearchExpress|searchhippo|searchterms\.it|Second\ Street\ Research|Seeker|Shai|Siphon|sitecheck|sitecheck.internetseer.com|SiteSnagger|SlySearch|SmartDownload|snagger|Snake|SpaceBison|Spegla|SpiderBot|sproose|SqWorm|Stripper|Sucker|SuperBot|SuperHTTP|Surfbot|SurfWalker|Szukacz|tAkeOut|tarspider|Teleport\ Pro|Templeton|TrueRobot|TV33_Mercator|UIowaCrawler|UtilMind|URLSpiderPro|URL_Spider_Pro|Vacuum|vagabondo|vayala|visibilitygap|VoidEYE|vspider|Web\ Downloader|w3mir|Web\ Data\ Extractor|Web\ Image\ Collector|Web\ Sucker|Wweb|WebAuto|WebBandit|web\.by\.mail|Webclipping|webcollage|webcollector|WebCopier|webcraft@bea|webdevil|webdownloader|Webdup|WebEMailExtrac|WebFetch|WebGo\ IS|WebHook|Webinator|WebLeacher|WEBMASTERS|WebMiner|WebMirror|webmole|WebReaper|WebSauger|Website|Website\ eXtractor|Website\ Quester|WebSnake|Webster|WebStripper|websucker|webvac|webwalk|webweasel|WebWhacker|WebZIP|Wget|Whacker|whizbang|WhosTalking|Widow|WISEbot|WWWOFFLE|x-Tractor|^Xaldon\ WebSpider|WUMPUS|Xenu|XGET|Zeus.*Webster|Zeus [NC,OR] RewriteCond %{HTTP_USER_AGENT} ^.*(winhttp|clshttp|archiver|loader|harvest|extract|grab|miner).* [NC,OR] RewriteCond %{HTTP_USER_AGENT} ^.*(libwww-perl|java|curl|wget|python|nikto|scan).* [NC,OR] RewriteCond %{HTTP_USER_AGENT} ^.*(<|>|'|%0A|%0D|%27|%3C|%3E|%00).* [NC] #RewriteRule .* - [F,L] # Send all blocked request to homepage with 403 Forbidden error! RewriteRule ^(.*)$ index.php [F,L] ########## End - Rewrite rules to block out some common exploits # Uncomment following line if your webserver's URL # is not directly related to physical file paths. # Update Your Joomla! Directory (just / for root) RewriteBase / ########## Begin - Joomla! core SEF Section #RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_URI} !^/index.php RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC] RewriteRule (.*) index.php RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L] ########## End - Joomla! core SEF Section
05 Mai 2010 18:40 #6 par lavsteph
regarde les modifications de ce post , cela devrait régler ton soucis d'accent.
