Extensions-tierces
[ regle ]Besoin d'aide pour l'installation d'un composant de contact
15 years 7 months ago - 15 years 7 months ago #23715
by charnalt
je souhaite modifier la partie contact de mon site et j'aimerai utiliser le composant Contact Form FX de
de www.flashxml.net/contact-form.html#swmi-joomla
mais il ne s'installe pas si facilement.
Pourriez-vous m'explique comment l'installer sur mon site ?
je ne sais même pas si je dois télécharger le module et le plugin.
je souhaite simplement que le visiteur clic sur le menu contact pour pouvoir envoyer un mail, je ne souhaite as que le composant soit sur la page home.
voila les instructions en anglais, mon niveau d'anglais est si pauvre que j’hésite a effectuer seul les instructions.
Joomla Module Instructions:
1. There are two files to download (both under GPL License):
a. Joomla Module (version 1.5 or version 1.6) that you have to install and enable
b. Free package
2. Create a new folder inside your Joomla folder called flashxml, inside this folder create a new one called contactformfx and copy the content of the free package there
3. If you copied the free package to a location different than the one above, update the Path from module's parameters accordingly
4. Customize your Contact Form FX using the Live Demo from the top of this page. Download the ZIP file and use the included settings.xml file to overwrite flashxml/contactformfx/settings.xml
Note that the Joomla Module can only be used once in your website.
Joomla Plugin Instructions:
a. Joomla Plugin (version 1.5 or version 1.6) that you have to install and enable
b. Free package
3. If you copied the free package to a location different from the one above, update the Path from module's parameters accordingly
4. Add {contactformfx}{/contactformfx} where you want the Flash to show up in your article
5. Customize your Contact Form FX using the Live Demo from the top of this page. Download the ZIP file and use the included settings.xml file to overwrite flashxml/contactformfx/settings.xml
6. The default name for the settings file is settings.xml, but if you want to use another file (for example settings2.xml), specify the name like this: {contactformfx settings="settings2.xml"}{/contactformfx} where you want the component to show up in your article
7. In some cases the width and height will not be read from the settings.xml file but you can specify them like this: {contactformfx width="400" height="300"}{/contactformfx}. Don't forget to provide your own width and height values, since 400 and 300 are just examples.
c'est complique ?
merci pour votre aide
thierry
PS : il existe d'autre extension de ce type mais celle-ci est assez jolie
b. Free package
b. Free package
c'est complique ?
thierry
Last edit: 15 years 7 months ago by charnalt.
15 years 7 months ago #23719
by A4C
A votre disposition pour tout soucis avec Joomla, PHPBB ou CashCrusader.
Hébergement "Pro" sans limites à 3€/Ht/mois
Replied by A4C on topic Re: Besoin d'aide pour l'installation d'un composant de contact
Bonsoir, non ce n'est pas très compliqué en fait tu dois avoir accès via FTP à ton root Joomla.
Dedans tu crée un nouveau dossier nommé flashxml puis à l'intèrieur de celui-ci un autre dossier nommé lui contactformfx ensuite tu upload le fichier Free package dedans.
Essaie déjà ça pour la customisation et surtout la sécurisation du truc lol c'est un peu plus ch...
Mais si tu as besoin d'aide reviens par là.
The following user(s) said Thank You: charnalt
15 years 7 months ago - 15 years 7 months ago #23720
by charnalt
Replied by charnalt on topic Re: Besoin d'aide pour l'installation d'un composant de contact
Merci A4C
est tu sur le chat ?
je vais voir ça, je vais surement revenir
merci encore
Thierry
je viens de voir ton site, intéressant.
j'aurai aime le connaitre plus tôt
merci encore
Thierry
15 years 7 months ago #23789
by charnalt
Zut
je viens de m’apercevoir que cette extension ne proposais pas de "capcha"
je vais devoir attendre
Merci comme meme A4C
