erreur 404 sur les pages site
13 years 8 months ago #31055 by lavsteph
Bonsoir Nath,
je crois que tu te compliques la vie en voulant comme ceal
Tu as chez ton hébergeur la possibilité de créer plusieurs sous domaine
  • miroir.monsite.com
  • miroir2.monsite.com
  • miroir3.monsite.com
  • ainsi de suite ...
ce sera bien plus simple que d'essayer de faire de la réécriture dans un autre dossier d'uns sous-domaine
Le htaccess suivant conviendra dans tous les cas
RewriteEngine On
IndexIgnore *
Options +FollowSymLinks All -Indexes
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site block out the operations listed below
# This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to base64_encode data within the URL.
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block out any script that includes a <script> tag in URL.
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL.
# Block out any script trying to modify a _REQUEST variable via URL.
# Return 403 Forbidden header and show the content of the root homepage
RewriteRule .* index.php [F]
## End - Rewrite rules to block out some common exploits.
RewriteCond %{HTTP_HOST} !^www\. [NC]
RewriteRule ^(.*)$ http://www.%{HTTP_HOST}/$1 [R,L]
RewriteBase /
## Begin - Joomla! core SEF Section.
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
# and the request is for something within the component folder,
# or for the site root, or for an extensionless URL, or the
# requested URL ends with one of the listed extensions
RewriteCond %{REQUEST_URI} /component/|(/[^.]*|\.(php|html?|feed|pdf|vcf|raw))$ [NC]
# and the requested path and file doesn't directly match a physical file
# and the requested path and file doesn't directly match a physical folder
# internally rewrite the request to the index.php script
RewriteRule .* index.php [L]
## End - Joomla! core SEF Section.
The following user(s) said Thank You: tonnerria
13 years 8 months ago #31056 by tonnerria
ah d'accord , je note alors,
Time to create page: 0.137 seconds
