comment ajouter position de module a gauche sur template joomla photocouds 1.6
15 years 3 months ago - 15 years 3 months ago #25321 by sympa
voila, tout est dans le titre voici une photo des positions, j'aimerais donc ajouter une position sur la gauche identique à celle de droite ou se trouve la pub. voila voila.
Attachment joomlaphotocloud.jpg not found
voici le code de la page index du template
_______le code commence ici__________________________________________ <?php /** * Template for Joomla!. * See readme.txt for more details on how to use the template. */ defined('_JEXEC') or die; require_once dirname(__FILE__) . DIRECTORY_SEPARATOR . 'functions.php'; // Create alias for $this object reference. $document = & $this; // Shortcut for template base url. $templateUrl = $document->baseurl . '/templates/' . $document->template; // Initialize version-specific view. $view = $this->artx = ('1.6' == $GLOBALS['version']->RELEASE) ? new ArtxPage16($this) : new ArtxPage15($this); // Decorate component with style. $view->componentWrapper(); ?> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="<?php echo $document->language; ?>" lang="<?php echo $document->language; ?>" > <head> <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE8" /> <jdoc:include type="head" /> <link rel="stylesheet" href="<?php echo $document->baseurl; ?>/templates/system/css/system.css" type="text/css" /> <link rel="stylesheet" href="<?php echo $document->baseurl; ?>/templates/system/css/general.css" type="text/css" /> <link rel="stylesheet" type="text/css" href="<?php echo $templateUrl; ?>/css/template.css" media="screen" /> <!--[if IE 6]><link rel="stylesheet" href="<?php echo $templateUrl; ?>/css/template.ie6.css" type="text/css" media="screen" /><![endif]--> <!--[if IE 7]><link rel="stylesheet" href="<?php echo $templateUrl; ?>/css/template.ie7.css" type="text/css" media="screen" /><![endif]--> <script type="text/javascript">if ('undefined' != typeof jQuery) document._artxJQueryBackup = jQuery;</script> <script type="text/javascript" src="<?php echo $templateUrl; ?>/jquery.js"></script> <script type="text/javascript">jQuery.noConflict();</script> <script type="text/javascript" src="<?php echo $templateUrl; ?>/script.js"></script> <script type="text/javascript">if (document._artxJQueryBackup) jQuery = document._artxJQueryBackup;</script> </head> <body class="<?php echo $view->bodyClass(); ?>"> <div id="sub-main"> <?php if ($view->containsModules('user3', 'extra1', 'extra2')) : ?> <div class="sub-nav"> <div class="sub-nav-l"></div> <div class="sub-nav-r"></div> <div class="sub-nav-outer"> <div class="sub-nav-wrapper"> <div class="sub-nav-inner"> <?php if ($view->containsModules('extra1')) : ?> <div class="sub-hmenu-extra1"><?php echo $view->position('extra1'); ?></div> <?php endif; ?> <?php if ($view->containsModules('extra2')) : ?> <div class="sub-hmenu-extra2"><?php echo $view->position('extra2'); ?></div> <?php endif; ?> <?php echo $view->position('user3'); ?> </div> </div> </div> </div> <div class="cleared reset-box"></div> <?php endif; ?> <div class="sub-header"> <div class="sub-header-wrapper"> <div class="sub-header-inner"> <div class="sub-headerobject"></div> <div class="sub-logo"> <h1 class="sub-logo-name"><a href="<?php echo $document->baseurl; ?>/">CestMonStyle.Com</a></h1> <h2 class="sub-logo-text">Votez pour votre model favori !</h2> </div> </div> </div> </div> <div class="cleared reset-box"></div><div class="sub-sheet"> <div class="sub-sheet-tl"></div> <div class="sub-sheet-tr"></div> <div class="sub-sheet-bl"></div> <div class="sub-sheet-br"></div> <div class="sub-sheet-tc"></div> <div class="sub-sheet-bc"></div> <div class="sub-sheet-cl"></div> <div class="sub-sheet-cr"></div> <div class="sub-sheet-cc"></div> <div class="sub-sheet-body"> <?php echo $view->position('banner1', 'sub-nostyle'); ?> <?php echo $view->positions(array('top1' => 33, 'top2' => 33, 'top3' => 34), 'sub-block'); ?> <div class="sub-content-layout"> <div class="sub-content-layout-row"> <div class="sub-layout-cell sub-content"> <?php echo $view->position('banner2', 'sub-nostyle'); if ($view->containsModules('breadcrumb')) echo artxPost($view->position('breadcrumb')); echo $view->positions(array('user1' => 50, 'user2' => 50), 'sub-article'); echo $view->position('banner3', 'sub-nostyle'); if ($view->hasMessages()) echo artxPost('<jdoc:include type="message" />'); echo '<jdoc:include type="component" />'; echo $view->position('banner4', 'sub-nostyle'); echo $view->positions(array('user4' => 50, 'user5' => 50), 'sub-article'); echo $view->position('banner5', 'sub-nostyle'); ?> <div class="cleared"></div> </div> <?php if ($view->containsModules('right')) : ?> <div class="sub-layout-cell sub-sidebar1"> <?php echo $view->position('right', 'sub-block'); ?> <div class="cleared"></div> </div> <?php endif; ?> </div> </div> <div class="cleared"></div> <?php echo $view->positions(array('bottom1' => 33, 'bottom2' => 33, 'bottom3' => 34), 'sub-block'); ?> <?php echo $view->position('banner6', 'sub-nostyle'); ?> <div class="cleared"></div> </div> </div> <div class="sub-footer"> <div class="sub-footer-body"> <div class="sub-footer-center"> <div class="sub-footer-wrapper"> <div class="sub-footer-text"> <?php if ($view->containsModules('copyright')): ?> <?php echo $view->position('copyright', 'sub-nostyle'); ?> <?php else: ?> <?php ob_start(); ?> <p>Copyright © %YEAR%. All Rights Reserved.</p><br /><br /> <div class="cleared"></div> <p class="sub-page-footer"><a href="http://www.templates-themes.de">Template</a> Designed by <a href="http://www.barockrahmenkauf24.de/">Prunkrahmen</a> .</p> <?php echo str_replace('%YEAR%', date('Y'), ob_get_clean()); ?> <?php endif; ?> </div> </div> </div> <div class="cleared"></div> </div> </div> </div> <?php echo $view->position('debug'); ?> </body> </html> __________________________le code se termine ici ____________________________
voila, que dois je modifier sur ce fichier pour ajouter la position à gauche et sur quels autres fichiers je dois intervenir merci a vous !
Last edit: 15 years 3 months ago by Peter. Reason: mise en forme du code avec les balises
Time to create page: 0.130 seconds
