- Joomla 2.5
- Extensions tierces
- Composants
- Problème d'affichage des contenus FLEXIcontent
Question Problème d'affichage des contenus FLEXIcontent
- micker
20 Jui 2013 09:56 #13
par micker
Réponse de micker sur le sujet Problème d'affichage des contenus FLEXIcontent
tu vois y a des erreurs
exemple
gatecameroun.com/index.php/restaurants/r...103-amhorec-traiteur
JDatabaseMySQLi::query: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ' cr.rating_count, ((cr.rating_sum / cr.rating_count)*20) as score FROM gt_flexic' at line 1 SQL=SELECT t.access as type_access, t.name as typename, t.alias as typealias, , cr.rating_count, ((cr.rating_sum / cr.rating_count)*20) as score FROM gt_flexicontent_items_ext as ie JOIN gt_flexicontent_types AS t ON t.id = ie.type_id LEFT JOIN gt_content_rating AS cr ON cr.content_id = ie.item_id WHERE ie.item_id=103
Call stack
# Function Location
1 JSite->dispatch() /home/mygate/public_html/index.php:42
2 JComponentHelper::renderComponent() /home/mygate/public_html/includes/application.php:197
3 JComponentHelper::executeComponent() /home/mygate/public_html/libraries/joomla/application/component/helper.php:351
4 require_once() /home/mygate/public_html/libraries/joomla/application/component/helper.php:383
5 JController->execute() /home/mygate/public_html/components/com_flexicontent/flexicontent.php:119
6 FlexicontentController->display() /home/mygate/public_html/libraries/joomla/application/component/controller.php:761
7 JController->display() /home/mygate/public_html/components/com_flexicontent/controller.php:544
8 FlexicontentViewItem->display() /home/mygate/public_html/libraries/joomla/application/component/controller.php:722
9 ParentClassItem->getItem() /home/mygate/public_html/components/com_flexicontent/views/item/view.html.php:112
10 ParentClassItem->_loadItem() /home/mygate/public_html/administrator/components/com_flexicontent/models/parentclassitem.php:230
11 JDatabase->loadObject() /home/mygate/public_html/administrator/components/com_flexicontent/models/parentclassitem.php:752
12 JDatabaseMySQLi->execute() /home/mygate/public_html/libraries/joomla/database/database.php:1062
13 JError::raiseError() /home/mygate/public_html/libraries/joomla/database/database/mysqli.php:396
14 JError::raise() /home/mygate/public_html/libraries/joomla/error/error.php:251
Après je vois un composant de SEF .. desactive pour les tests ...
poste sur le forum de flexicontent pour que l'on puisse mieux t'aider
a+
exemple
Call stack
# Function Location
a+
- dakama
- Remerciements reçus 2
20 Jui 2013 10:40 #14
par dakama
Réponse de dakama sur le sujet Problème d'affichage des contenus FLEXIcontent
D'accord, merci pour ton aide micker.
Je vais retourner sur le forum flexicontent.
A+
Crdlt,
A+
Crdlt,
- Joomla 2.5
- Composants
Temps de génération de la page : 0.178 secondes
