besoin d'aide svp , messages d'erreur
- alaimarrakchi
Topic Author
- New Member
14 years 9 months ago #27403
by alaimarrakchi
besoin d'aide svp , messages d'erreur was created by alaimarrakchi
Bonjour à tous et toutes,
Etant débutant avec joomla, je voudrais l'installer sur mon serveur mutualisé chez nexen services.(joomlaversion 2.5.1)
J'ai dézipper et transférer tous les dossiers et fichiers, j'ai renommé le htacces.tx et .htacess.tx , et placé les autorisation 775 sur les dossiers et 777 sur les fichiers.
lorsque je lance l'installation (via Firefox), je reçois plusieurs messages d'erreurs, que voici:
Warning: session_start() [function.session-start]: open(tcp://10.0.6.120:11211/sess_0f2a2ecc3ba7b3255bd8044c6e0ea38d, O_RDWR) failed: No such file or directory (2) in /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php on line 492
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php:492) in /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php on line 492
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php:492) in /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php on line
Warning: session_write_close() [function.session-write-close]: open(tcp://10.0.6.120:11211/sess_0f2a2ecc3ba7b3255bd8044c6e0ea38d, O_RDWR) failed: No such file or directory (2) in /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php on line 633
Warning: session_write_close() [function.session-write-close]: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (tcp://10.0.6.120:11211) in /home/user/s/h/a/sharqwest1/www/client/joomlatest/libraries/joomla/session/session.php on line 633
Que dois je faire, pourriez-vous m'aider SVP ?
grand merci
grand merci
14 years 9 months ago #27404
by Naw3r
Replied by Naw3r on topic Re: besoin d'aide svp , messages d'erreur
Salut;
As tu bien créé un répertoire nommé sessions à la racine de ton site ?
Si ce n'est toujours pas résolu essaie de vérifier auprès te ton hébergeur que le registrer_globals soit bien sur OFF dans le php.ini (ça dépend des hébergeurs mais souvent tu peux modifier ça via le panel d'administration de ton hébergeur)
- alaimarrakchi
Topic Author
- New Member
14 years 9 months ago #27408
by alaimarrakchi
Replied by alaimarrakchi on topic Re: besoin d'aide svp , messages d'erreur
Bonjour Naw3r,
merci pour ton aide.
Il n'y avais pas de dossier "sessions", je l'ai créé , mais cela ne change rien.
je vais contacter nexenservices, mon hébergeur pour qu'il contrôle le register_globals, car je n'y ai pas accès
je reviens après pour t'informer
- alaimarrakchi
Topic Author
- New Member
14 years 9 months ago #27410
by alaimarrakchi
Bonjour Simon,
ok, merci j'ai envoyé à nexen le nouveau fichier (car les htacces, ne peuvent pas être placés par l'utilisateur, mais par le technicien nexen, pour des raisons de sécurités disent-ils)
je dois attendre lundi maintenant... !
merci en tout cas
bon WE
merci en tout cas
bon WE
14 years 9 months ago #27419
by Naw3r
As tu essayé de transféré ton htaccess.txt via FTP, et ensuite de le renommer directement en .htaccess ?
Time to create page: 0.158 seconds
